Anonymous
How to clear the retransmit counters for fciptunnels and circuits
Hello Team
PROBLEM DESCRIPTION:
I would like to know what FOS command to use the clear/reset the retransmit and out of order packet counters as listed below in the output from the command "portshow fciptunnel 16 -pc".
I have tried both portstatsclear and statsclear and these only clear the FC stats.
NY55W-78K-01-A:admin> portshow fciptunnel all -c
Tunnel Circuit OpStatus Flags Uptime TxMBps RxMBps ConnCnt CommRt Met
16 - Up c---- 1h15m17s 0.11 17.15 61 - -
16 0 ge0 Up ----s 1h15m17s 0.05 8.58 81 1000/1000 0
16 1 ge1 Up ----s 1h15m8s 0.05 8.57 85 1000/1000 0
17 - Up c---- 1h15m5s 0.03 3.91 20 - -
17 0 ge2 Up ----s 1h15m6s 0.01 0.97 43 1000/1000 0
17 1 ge3 Up ----s 1h15m5s 0.01 0.98 50 1000/1000 0
17 2 ge4 Up ----s 1h15m5s 0.01 0.98 41 1000/1000 0
17 3 ge5 Up ----s 1h15m6s 0.01 0.97 43 1000/1000 0
Flags: tunnel: c=compression f=fastwrite t=Tapepipelining F=FICON T=TPerf
circuit: s=sack
NY55W-78K-01-A:admin> portshow fciptunnel 16 -pc |grep -Ei 'retransmits|order|sequence'
Retransmits: 145400
Out Of Order: 26732153
Max Retransmits: 8
Retransmits: 73393
Out Of Order: 13358645
Max Retransmits: 8
Retransmits: 7200
Please advise
Thanks
Chetan.R
Anonymous
Re: How to clear the retransmit counters for fciptunnels and circuits
Hi -
last status I had on this subject from Brocade support was : it's not possible de clear statistics for fciptunnel, you have to reboot for that.
RFE in progress ...
Hope this helps
Kind regards,
david
