Occasional Contributor
Accepted Solution
How to check timestamp for NPIV going offline and online
Do anyone know through CLI how to check the timestamp for NPIV go offline and online, something similar to fabriclog -s
Valued Contributor
Re: How to check timestamp for NPIV going offline and online
Hi,
That should be checked on the Access Gateway device where the NPIV dev is connected to because the switch provides very little info about that.
You may be able to check what you need by executing "portlogdumpport <port>" on the port where that NPIV dev is logged.
rgds,
felipon
I should have mention that switch is not Access Gateway. The san port is an enable NPIV on dcx FOS 7.0.1a
Frequent Contributor
You could grep the director's portlogdump for the fdiscs like:
portlogdump | grep fffffe
I just wonder if they would also explicitely log out by sending a logo to fffffe.
But: depending on how much is going on in your fabric, it could be that your portlogdump covers only a few minutes...
Thanks Felipon and Sabestian, it look like portlogdump is near enough answer to my issue.
