New Contributor
How do I resolve a Laser_Fit error on a 48K
How to resolve a Laser_Fit error on a Brocade 48K?
Valued Contributor
Re: How do I resolve a Laser_Fit error on a 48K
Hi, I believe this should read "LASER_FLT" (laser fault) and it usually tells you to replace SFP
Anonymous
hmm!! You can attempt to disable and enable the port once to reinitialize, some times it works.
Even post the above activity if the status is same replace the SFP :smileywink:
