Turn on suggestions
Showing results for
08-10-2018 05:13 PM
Have a two switches set as principal roles . need to force one to subordinate
08-10-2018 09:23 PM
it is strong that two switch in the "SAME" fabric ( ISL ) are as principal
to force one the command is
fabricprincipal -f
