Anonymous
How To Enable SSH on DS-4100B Running FOS v5.0.1b
Hello
Please advise
Thanks
Chetan R
External Moderator
Re: How To Enable SSH on DS-4100B Running FOS v5.0.1b
refer CLI Guide command "secmodeenable"
Secure Shell access is configurable by the Telnet Policy that is available through Secure Fabric OS.
However, Fabric OS v4.4.0 and v5.0.1 support Secure Shell whether or not Secure Fabric OS is
licensed.
TechHelp24
Anonymous
Hello
Thank you for your response,
I did refer the CLI Guide v5.0 for secmodeenable, i didn't find option to enable SSH
Synopsis: secmodeenable | ]
Will the following have the option to enable SSH
#switchdisable
#configure
     system services(yes, y, no, n): yes
Please advise
Thanks
Chetan R
Anonymous
Hello
Found the following solution to enable SSH on switches running older FOS
In the FOS v5.0.1b , the SSH is already enabled henceforth execute the following commands to see the status of the SSH in the switch.
1) chkconfig
2) ps -ef|grep ssh
Example:
SW1:root> chkconfig
        Flag                 State
        asd                  on
        authd                on
        cald                 on
        crond                on
        diag                 on
        emd                  on
        essd                 on
        evmd                 on
        fabos                on
        fabosSetDbg          off
        fabricd              on
        fcpd                 on
        fdmid                on
        ficud                on
        fspfd                on
        fwd                  on
        hamd                 on
        hmond                on
        ipc                  on
        msd                  on
        mtracer              off
        network              on
        nsd                  on
        panicdump            on
        pcmcia               off
        pdmd                 on
        psd                  on
        pttest               on
        raslogd              on
        rcsd                 on
        rpcd                 on
        secd                 on
        setmodem             on
        snmpd                on
        sshd                 on          <<<<<< Look to see if sshd is ON
        suppress_asserts     off
        suppress_panic_mode  off
        swdd                 on
        syslog               on
        track_changes        on
        tsd                  on
        wdtd                 on
        webd                 on
        zoned                on
SW1:root> ps -ef|grep ssh
root       628     1  0  2011 ?        00:00:00 /usr/sbin/sshd
root      5986     1  0  2011 ?        00:00:00
root      5990     1  0  2011 ?        00:00:00
root      6261     1  0  2011 ?        00:00:00
root     23564     1  0  2011 ?        00:00:00
root       874   628  0 06:38 ?        00:00:00 /usr/sbin/sshd
root       875   874  0 06:38 ?        00:00:00 /usr/sbin/sshd
root      1644   628  0 08:36 ?        00:00:01 /usr/sbin/sshd
root      1645  1644  0 08:36 ?        00:00:00 /usr/sbin/sshd
root      4566  4525  0 16:56 pts/3    00:00:00 grep ssh
If you find the sshd set to OFF, below is the command to enable SSH
Switch#chkconfig sshd on
Thanks
Chetan R
