Anonymous
Help with aliases
We used to have 2 sepperate Brocade 200 switches, we now have 2 200 and 2 300's connected as a mesh network acting as one fabric. We have 2 IBM ds3400 dual controler and 7 ESX servers with dual HBA.
My question is around Zoning in this new configuration.
Should I create the following aliases each with 2 members DS3400_1_A, DS3400_1_B or create the following aliases each with 1 member DS3400_1_A1, DS3400_1_A2, DS3400_1_B1, DS3400_1_B2?
External Moderator
Re: Help with aliases
--->>>... as a mesh ....
are all 4 Switches 2x 200 and 2x 300 in the same Fabric is correct ? Also are all 4 switch ISL's connected ?
should both array be a member of the same zone? or you want to create different Zone ?
TechHelp24
Anonymous
yes the 4 switches are in the same fabric they have 3 ISL each connectin as mesh to the other switches.
I think that it is better to have them in different Zones whilst I may endup with more zones. Any suggestions?
External Moderator
this makes no different if all servers have access to both array.
but if want to allow access determinated server to determine array then makes sense to create multiple zone.
as example:
Server 1,2 and 3 have only access to Array 1
Server 4,5 and 6 have only access to Array 2
Server 7 have access to both Array 1 and 2
TechHelp24
Anonymous
servers 123 will have access to array 1, servers 4567 to array 2.
External Moderator
in this case you need to create Mandatory TWO Zone
TechHelp24
Anonymous
So you would have a zone for array 1 and a zone for array 2, and not a zone for server 1 to array 1, zone for server 2 to array 1, etc giving each server its own zone?
External Moderator
I give your a example in my preview post.
here another example
zone1 contain Aliases:
Server 1
Server 2
Server 3
Array 1
zone2 contain Aliases:
Server 4
Server 5
Server 6
Server 7
Array 2
TechHelp24
