Occasional Contributor
Help required for command
Hi All,
I have a brocade switch model 300 and version v6.3.2e8.
It a slot based system and do not support command option "portshow -i <pirt_index_range>".
This command give me the data for all ports avialable in switch, but unfortunately this index range option is not avalabe in this version and i am looking for the command which gives me the data for all ports in single command.
Thanks for everyones help and support.
Regards,
Manish
External Moderator
Re: Help required for command
->It a slot based system....
-->>I have a brocade switch model 300
brocade 300 is not a slot based system.
can you post please from "switchshow" command the line "Switch Type" ?
TechHelp24
Frequent Contributor
to see ports 7 to 19:
for ((i=7;i<=19;i++)); do portshow $i; done
if you have to do that for several port ranges, define once:
poshow () { for((i=$1;i<=$2;i++)); do portshow $i; done; }
and then for 7-19 just type
poshow 7 19
Thank you all,
I got it there is no option to get all the ports data.
I need to fire a command one by one for all ports.
Thanks for all your suggestions and time.
Regards,
Manish
