New Contributor
Accepted Solution
HTTPS Webtool GUI Problem after upgraded to v8.1.*.
My environment:
Switch: Brocade 6505
Management console: Windows 10, IE 11, JAVA 8u151
Hello, I see some posts about HTTPS webtool GUI problem after upgraded to v8.1.*. I have same problem after upgraded from v8.0.1b to v8.1.1. HTTP webtool and CLI work no problem.
I ran "seccertmgmt show -all" and it shows that the HTTPS Server CA cert is "Exists", But the HTTPS switch (SW) cert is "Empty".
When I downgraded from v8.1.1 to v8.0.1, HTTPS webtool works no problem.
Therefore I tried to re-install my certs on v8.1.1. My switch cert is issued by Intermediate CA, and the Intermediate CA cert is issued by Root CA, so three certs (switch, Intermediate CA, Root CA) need to be installed.
I successfully installed Root CA cert. But I can't install Intermediate CA cert and switch cert with error message "Error: unable to get local issuer certificate".
1. To install Root CA cert, I ran below.
seccertmgmt import -ca -server https -protocol scp -ipaddr *.*.*.* -remotedir /*/* -certname root-ca.pem
Success: imported https certificate [root-ca.pem].
Certificate file in configuration has been updated.
2. To install Intermediate CA, I ran below.
seccertmgmt import -ca -server https -protocol scp -ipaddr *.*.*.* -remotedir /*/* -certname intermediate-ca.pem
3. To install switch cert, I ran below.
seccertmgmt import -cert https -protocol scp -ipaddr *.*.*.* -remotedir /*/* -certname swtch.pem
Does anyone know how to install Intermediate CA cert and switch cert?
Thank you,
Broadcom Moderator
Re: HTTPS Webtool GUI Problem after upgraded to v8.1.*.
Hello,
Try the procedure below:
  • Managed to find the CA-inter-certificate and merged it with the CA-root certificate, it should be imported with success as a CA server https certificate.
    Then import the switch-certificate for HTTPS.
    The switch-certificate is unchained but both chained and unchained switch-certificates are working.
  • Log from the implementation below.
    switch> seccertmgmt show -all
    ssh private key:
    Does not Exist
    ssh public keys available for users:
    None
    Certificate Files:
    Protocol Client CA Server CA SW CSR PVT Key Passphrase
    FCAP Empty NA Empty Empty Empty Empty
    RADIUS Empty Empty Empty Empty Empty NA
    LDAP Empty Exist Empty Empty Empty NA
    SYSLOG Empty Empty Empty Empty Empty NA
    HTTPS NA Empty Empty Exist Exist NA
    switch> seccertmgmt import -ca -server https -protocol scp -ipaddr xx.xx.xx.xx -remotedir /cert -certname rootca-chained.pem -login admin
    admin@xx.xx.xx.xx's password:
    Success: imported https certificate [rootca-chained.pem].
    switch> seccertmgmt import -cert https -protocol scp -ipaddr xx.xx.xx.xx -remotedir /cert -certname xx.xx.xx.xx.pem -login admin
    Success: imported https certificate [xx.xx.xx.xx.pem].
    Secure http has been enabled.
    ssh private key:
    Does not Exist
    None
    Certificate Files:
    HTTPS NA Exist Exist Exist Exist NA
Broadcom Moderator
[ Edited ]
Previous documentations were not completely accurate around the configuration.
Please find attached the 8.2 admin guide where the description is in page 219.
New Contributor
Hello Thierry.Zimmermann,
Sorry for the late reply.
I followed v8.2 manual and successfully installed the merged CA cert file ! But I don't know why Brocade dosen't include that information in v8.1 manual...
Anyway, Thank you for your help!
