Occasional Contributor
HPAJ764A -> QLE2562 Problems.
Hi, I have a HPAJ764A -> QLE2562 card on a Linux RH5 and it only logs in the fabric (brocade 4100) if we force the speed to 2GB and it only work for few minutes and then it goes In_Sync again, can anyone help me? I think it is a driver related issue but dont know how to fix.
Reagrds
Paulo Serra
Valued Contributor
Re: HPAJ764A -> QLE2562 Problems.
Hi,
On the one hand, a good option would be to upgrade the HBA driver (what's the version?).
On the other, please, try the following and post the result:
- once you get the port to be ONLINE, clear the stats (portstatsclear <port>) and once it fails, get the output of portshow <port> and portstatsshow <port>.
- can you paste the output of sfpshow <port> -f? (what's the FOS running on the switch?)
- what error do you get when setting the speed at auto or 4G?
rgds
Hi,
After a while the port goes down again, here is the portlogshow:
portIndex:  31
portName: LPC0000ORC03_HBA1
portHealth: No Fabric Watch License
Authentication: None
portDisableReason: None
portCFlags: 0x1
portFlags: 0x4041        PRESENT LED
LocalSwcFlags: 0x0
portType:  10.0
POD Port: Port is licensed
portState: 2    Offline
Protocol: FC
portPhys:  5    No_Sync         portScn:   2    Offline
port generation number:    1452
state transition count:    406
portId:    011f00
portIfId:    4302001f
portWwn:   20:1f:00:05:1e:03:8c:b9
portWwn of device(s) connected:
Distance:  normal
portSpeed: 2Gbps
LE domain: 0
FC Fastwrite: OFF
Interrupts:        1602797    Link_failure: 200346     Frjt:         0
Unknown:           0          Loss_of_sync: 200347     Fbsy:         0
Lli:               1602797    Loss_of_sig:  1
Proc_rqrd:         29         Protocol_err: 0
Timed_out:         0          Invalid_word: 596603
Rx_flushed:        0          Invalid_crc:  0
Tx_unavail:        0          Delim_err:    0
Free_buffer:       0          Address_err:  0
Overrun:           0          Lr_in:        1
Suspended:         0          Lr_out:       1
Parity_err:        0          Ols_in:       1
2_parity_err:      0          Ols_out:      1
CMI_bus_err:       0
SWDR01:cesce> portstatshow 31
rbash: portstatshow: command not found
SWDR01:cesce> portstatsshow 31
stat_wtx                38485784    4-byte words transmitted
stat_wrx                592352504   4-byte words received
stat_ftx                2278790     Frames transmitted
stat_frx                117211453   Frames received
stat_cdr_frx            0           Class 2 frames received
stat_c3_frx             117211453   Class 3 frames received
stat_lc_rx              0           Link control frames received
stat_mc_rx              0           Multicast frames received
stat_mc_to              0           Multicast timeouts
stat_mc_tx              0           Multicast frames transmitted
tim_rdy_pri             0           Time R_RDY high priority
tim_txcrd_z             0           Time BB credit zero (2.5Us ticks)
er_enc_in               0           Encoding errors inside of frames
er_crc                  0           Frames with CRC errors
er_trunc                0           Frames shorter than minimum
er_toolong              0           Frames longer than maximum
er_bad_eof              0           Frames with bad end-of-frame
er_enc_out              596847      Encoding error outside of frames
er_bad_os               3814394127  Invalid ordered set
er_rx_c3_timeout        0           Class 3 receive frames discarded due to timeout
er_tx_c3_timeout        0           Class 3 transmit frames discarded due to timeout
er_c3_dest_unreach      0           Class 3 frames discarded due to destination unreachable
er_other_discard        0           Other discards
er_zone_discard         0           Class 3 frames discarded due to zone mismatch
er_crc_good_eof         0           Crc error with good eof
er_inv_arb              0           Invalid ARB
open                    0           loop_open
transfer                0           loop_transfer
opened                  0           FL_Port opened
starve_stop             0           tenancies stopped due to starvation
fl_tenancy              0           number of times FL has the tenancy
nl_tenancy              0           number of times NL has the tenancy
zero_tenancy            0           zero tenancy
QLogic Corp. ISP2532-based 8Gb Fibre Channel to PCI Express HBA (rev 02)
8.03.07.08.32.1-k
Former Brocadian
pserra, I noticed you are running the 8.03.x firmware by Q.  Their current driver set is 8.05.x.  Just FYI.
Regards,
Mike Eversole
Brocade Community Manager
Former Brocadian
But beyond that, I would suggest speaking to Qlogic regarding their FC adapters.
Regards,
Mike Eversole
Valued Contributor
Hi,
it is scary the number of existing bugs in 8.04 and previous driver releases:
http://filedownloads.qlogic.com/files/Driver/85089/LinuxDriverRelease.txt
I'd recommend you to upgrade the drivers and then see if problems persist.
rgds
