Anonymous
HP c7000 enclosure moved Blade from one chassis to another
And now the blade is in persistent disable mode and will not respond to anything.
I have tried
    1. portcfgdefault
    2. portdisable
    3. portenable
It comes up with the following error
Switch may be disabled, POD license is NOT installed, 7500E upgrade license is NOT installed, slot is off, port is persistently disabled or if this is VE port and associated GE is not in FCIP mode.
WT says port is Persistent Disable and both enable and disable are greyed out.
here is port cfg
portName:
portHealth: No Fabric Watch License
Authentication: None
portDisableReason: Persistently disabled port
portCFlags: 0x0
portFlags: 0x21 PRESENT DISABLED
portType:  11.0
POD Port: Port is licensed
portState: Persistently Disabled
portPhys:  5No_Sync
portScn:   2Offline
port generation number:    224
portId:    070b00
portIfId:    4302000d
portWwn:   20:0b:00:05:1e:09:fe:7b
portWwn of device(s) connected:
Distance:  normal
portSpeed: Negotiating
LE domain: 0
FC Fastwrite: OFF
Interrupts:        0          Link_failure: 0          Frjt:         0
Unknown:           0          Loss_of_sync: 0          Fbsy:         0
Lli:               0          Loss_of_sig:  0
Proc_rqrd:         0          Protocol_err: 0
Timed_out:         0          Invalid_word: 0
Rx_flushed:        0          Invalid_crc:  0
Tx_unavail:        0          Delim_err:    0
Free_buffer:       0          Address_err:  0
Overrun:           0          Lr_in:        0
Suspended:         0          Lr_out:       0
Parity_err:        0          Ols_in:       0
2_parity_err:      0          Ols_out:      0
CMI_bus_err:       0
Port part of other ADs: No
switch has a current fabric license
I tried to persistentenable in WT and it said Operation is not supported on this port.
Anonymous
Re: HP c7000 enclosure moved Blade from one chassis to another
Try portcfgpersistentenable.
Anonymous
No dice
I get the following
portcfgpersistentenable 11
portcfgpersistentenable failed.  Operation not supported.
Anonymous
Mezz cards were 8gig and i swapped them to 4 gig.
Still the same issue.
Anonymous
Did you end up getting a resolution for this portcfgpersistentenable operation failed?
I'm getting the same issue on my C7000 chassis.
