Turn on suggestions
Showing results for
03-23-2011 11:34 AM
Hi,
Has anyone experienced issues with HP Virtual Connect on Brocade? We're using:
5100's @ FOS 6.3.1a
Ports from the Virtual Connect are giving strange logins (no information about the ports when viewed in Zoning Admin view).
Just wondering if there's any known issues before I take the switch up to 6.4.1a. NPIV is on and running.
Thanks in advance.
Scott.
03-23-2011 12:14 PM
What do you mean? Are you missing virtual wwn's hanging of the port where the VC are connected?
Can you attach a printscreen?
Do you see the virtual wwwn's when running portloginshow or portshow ?
I've seen issues where VC wwn's did not complete a login and couldn't access storage as a result.
That was on 5.3.1a don't know the VC en OA firmwarelevels anymore.
Did you look on the HP Spock or ITRC sites for issues and if so what where your findings?
