New Contributor
Accepted Solution
HP SN6500B 96/96 and HP B-series 10Gb SFP+ SRT with error Speed Mismatch / Incompatible SFP
We have installed a 6500B and we want to add SFP to connect 10Gb ISL between a 6500B switch and a 6000B switch. In both cases, the SFP show errors. Support matrix indicates that they are compatible.
The errors shown are:
  94  94   b45e00   id    8G       Mod_Inv     FC  "Speed Mismatch / Incompatible SFP"
  95  95   b45f00   id    8G       Mod_Inv     FC  "Speed Mismatch / Incompatible SFP"
The SFP is HP B-series 10Gb SFP+ short range transceiver
You must perform some special configuration in the SFP port to be recognized?
Thanks for your help.
External Moderator
Re: HP SN6500B 96/96 and HP B-series 10Gb SFP+ SRT with error Speed Mismatch / Incompatible SFP
@FASAM10
->You must perform some special configuration in the SFP port to be recognized?
Yes.
First, you need a 10 Gb FC License, is this License Present ?
Second:
in HP SN6500B = Native Brocade 6520, the both First Octet can be used for 10 Gb FC in example from Port 0-7, and Port Speed must be set with the command "portcfgoctetspeedcombo" command.
keep in mind the command is disruptive, for details refer command reference guide
TechHelp24
Valued Contributor
New Contributor
the output of licenseshow command:
licenseshow:
licenseshow        :
rgRRGPLFTWJLCE9HPMZKGKJafBDDAT39B7LFN:
    Full Ports on Demand license - additional 48 port upgrade license
ADXMErRGXKR9mT7ttJNAfF73ZMZSXBL7BJGWN:
    Extended Fabric license
    Fabric Watch license
    Performance Monitor license
    Trunking license
    Fabric Vision license
I suppose that we need aditional 10 Gigabit FCIP/Fibre Channel (10G license)  to create a 10G ISL?
External Moderator
@FASAM10
as I mention both.
License and the octet must be configured for 10gb
TechHelp24
