New Contributor
Frame buffer differences between 5100 and 5300
Can someone explain to me why the frame buffers are different between 5100 and 5300? The datasheets state the following:
5100 - 2048 dynamically allocated, 1692 maximum per port
5300 - 1460 dynamically allocated, 268 maximum per port
Thank you in advance.
Regards,
Chetan.
External Moderator
Re: Frame buffer differences between 5100 and 5300
Due a ASIC restriction.
5100 Based Condor2 ASIC
5300 ( and Brocade 300 ) Based GoldenEye2 ASIC
Condor2 ASIC's ( same ASIC is used in DCX ) is powerfull as the GoldenEye2 ASIC's
TechHelp24
New Contributor
Thank you for your kind response. Much appreciated.
