Anonymous
Fos versions and HBA matrix
Hi guys,
  I´m facing the planification for a FOS upgrade in all my SAN, So I´m trying to get all the info to be ready to go, I have almost all I need, but can´t find in the release note the list for the firmware/drivers for some Qlogic´s HBA.
Does anyone know where I can find a matrix?
I need to check 2 different FOS versions and severals Qlogic´s models.
Thanks a lot!
Valued Contributor
Re: Fos versions and HBA matrix
Hi,
AFAIK the FOS releases are backwards compatible and there is no compatibility matrix that matches HBAs and FOS versions. Usually, these kind of checks have to be done between the storage array and HBA model/driver of the host. So the storage array vendor usually provides a compatibility matrix that shows the supported devices.
Rgds
