Turn on suggestions
Showing results for
06-10-2016 12:52 AM
Hi folks,
i just playing around with the new flow vision technlogy and get worried about the really small documentation. I want first to set up a monitor for our ISL trunk ports and in the docu there is a part how to do this:
flow --create f1 -feature monitor -egrport 24 -srcdev 022b00 -dstdev 033a0
So now my problem begins, i have 4 ISL ports an two different slots, so how to put in the egrport, i used 1/0 as this is the location of the master. And next i dont know what to use for srcdev and dstdev, i tried with switchid and switchwwn, but always got an error. Someone has already made it and can hep me here. I did not find any hints here.
Best regards, Peter
06-10-2016 01:47 AM
is MAPS configured ?
06-10-2016 02:44 AM
No it is not configured yet. Is that a prereq before using flow monitor?
Best regards,
Peter
06-10-2016 03:29 AM
Peter,
no MAPS is not mandatory but required for monitoring.
Additional, if i remember correct some features are are not available in 8G Platform. You don't specified:
Switch Type, FOS Release, and if the Switch is Fabric Vision Licensed.
06-13-2016 12:20 AM
OK.
It is an DCX8510-8 and the switch is fabric vision licensed.
FOS is 7.3.1.d
Best regards,
Peter
06-14-2016 12:04 AM
I opened an IBM problem record about the case, i will give some info if i managed to to it
06-16-2016 03:19 AM - edited 06-16-2016 03:34 AM
Hi Peter,
makes no sense to open a ticket.
First of all, what do you want to monitor on your ISL-Ports?
Do you have a special communikation between two end-devices or do you want to know who is using the ISL?
Without this informations it is very difficult to define a flow.
Do you have the Flow Vision Admin Guide? There everything is described.
06-22-2016 04:45 AM
Hi,
it was good to open a call, because we have a premium contract here :-)
With this help i could set up some flow monitors. I also read the flow admin guide, but in my opinion it is not the best document to start up in here. Your are right, there is a lot of info, but the usage examples are not well described and this was the problem for me to start up here...
I now learned that you simply could use scrdev "*" and dstdev "*" so that the flow monitor is in the "learning" mode. So there you can then see up to 64 Ports that are using the isl trunk between our two data center locations.
First i will upgrade FOS from 7.3.1d to new target release 7.4.1b, there are some changes in the monitoring tools and afterwards i will set up up MAPS and FLOW Monitor in our environment.
Thanx for your tips so far..
Best regards,
Peter
