Anonymous
Flash Memory Out of Range
Hi all,
the problem after upgrade the firmware is:
FW-1402 Res Flash 0, is above high boundary(High=85, Low=0). Current value  is 88 Percentage (%).
FW-1424 Switch status changed from HEALTHY to MARGINAL.
FW-1435 Switch status change contributing factor Flash: usage out of range.
ORANGE Important A situation exists where if not corrected, may result in a malfunctioning of the SAN.
I`ve done `supportSave -R" without any success.
Any Ideas?
best regards,
Ralf
Anonymous
Re: Flash Memory Out of Range
Firmware Upgrade to OS 5.3.2
External Moderator
--->>> Firmware Upgrade to OS 5.3.2
from which release ?
If the current FOS rel. lower as 5.2.x use the command "savecore -l"
TechHelp24
External Moderator
BTW, you are in the wrong Forum
post please such question in the future in Products, Technology, and Architecture
TechHelp24
Anonymous
Hello Support-Team,
the Command "savecore -l" it`s wrong.
"This command is no longer supported as of v5.3.0"
The Switch Release is v5.3.2.
Is there a new command?
best regards,
Ralf
External Moderator
savecore work as mentioned till FOS 5.2.x, and is not longer available in 5.3 or higher.
use here the command "supportftp"
for details / operands refer the Command Reference Manuals.
TechHelp24
Anonymous
thanks!
so the command is "supportftp -R" .... my last question, this command does not delete my configuration, or?
Ralf
External Moderator
Ralf,
No. The command not delete any kind of config, just move/delete dump file to ftp.
If you are satisfied with the responses please mark as 'Answered'.
If not, just let me know I can see to get more info.
I would appreciated if you rate the threads.
TechHelp24
Anonymous
I encountered the same problem when upgrading FOS on a Brocade 200E from v5.3.2a to v6.0.1a.
Time Level Message Service Number Count Message ID Switch
Wed Jun 16 2010 14:12:10 GMT+00:00 Information Firmwarecommit has started. Chassis 664 1 SULB-1003 SIGRUN
Wed Jun 16 2010 14:12:14 GMT+00:00 Warning Res Flash 0, is above high boundary(High=85, Low=0). Current value is 89 Percentage(%). Switch 665 1 FW-1402 SIGRUN
Wed Jun 16 2010 14:12:39 GMT+00:00 Warning Switch status changed from HEALTHY to MARGINAL. Switch 666 1 FW-1424 SIGRUN
Wed Jun 16 2010 14:15:22 GMT+00:00 Information Firmwarecommit has completed. Chassis 667 1 SULB-1004 SIGRUN
Wed Jun 16 2010 14:15:22 GMT+00:00 Information The new Version: Fabric OS v6.0.1a Chassis 668 1 SULB-1036 SIGRUN
I tried running supportSave but that did not affect the switch status which is still marginal.
I was going to continue upgrading this switch to v6.1.2b and then v6.2.1b, so should I just continue upgrading or should I first correct this marginal status issue?
