Anonymous
Firmware
Can anyone answer the question: while using the command >firmwaredownload I can update the firmware. Let's say I lost my admin and root password. The utility from brocade.com allows me to reset password if I only have versions 2.6.0d, 3.0.2g, 4.0.2b or higher. Let's say I have the same switch with no password problem and with highest version of firmware. Can I remove this firmware chip from this good switch, put it in switch that has the password problem, then run the recovering password utility and then return the old chip? Is it possible? Thank you in advance.
