Turn on suggestions
Showing results for
10-13-2010 10:53 AM
Will the firmware upgrade on a 4100 from 6.1 to 6.2 and eventually 6.4 be non-disruptive?. Does it do an hareboot similar to a firmware upgrade on a director 48K? Thanks
10-13-2010 09:25 PM
In a standalone Switch, Firmware upgrade is disruptive.
If you are satisfied with the responses please mark as 'Answered'.
If not, just let me know I can see to get more info.
I would appreciated if you rate the threads.
Thank you.
