Anonymous
Firmware upgrade for: McDATA(R) 4Gb Fibre Channel Switch Module for IBM BladeCenter(R)
Hi!
I have an IBM BladeCenter, with a 'McDATA(R) 4Gb Fibre Channel Switch Module for IBM BladeCenter(R)' installed in it. It says that the active sw version is: V5.5.1.10.0. It is working just okay, but does not know about aliases, and causes problems when i want to create a fabric.Where can i find firmware upgrade packages to this switch?
Thanks,
BR,
Marton
External Moderator
Re: Firmware upgrade for: McDATA(R) 4Gb Fibre Channel Switch Module for IBM BladeCenter(R)
Marton,
i have answer a question like this here, as severel time here in the community.
McDATA Blade Switches for IBM Blade Center, are genuine QLogic Blade.
Download are available here.
http://driverdownloads.qlogic.com/QLogicDriverDownloads_UI/Product_detail_new.aspx?oemid=324&companyid=6
For exact Details before you begin whit Download, installation of any possible wrong Firmware, refer accurately the Relese Notes and and IBM Part Number.
FYI: Any wrong Firmware will be made the Switch uselessly.
TechHelp24
