Contributor
Accepted Solution
Firmware Upgrade for Console
hello guys;
I can upgrade firmware via only console? i have imagen of new firmware in my laptop, i not access via ethernet or management interface.
thanks
Broadcom Moderator
Re: Firmware Upgrade for Console
Hi,
firmware cannot be transferred via serial line. If you have issues with ethernet connectivity, the other options is UBS key (brocade).
Contributor
Hello Martin;
When put USB in switch
switch:admin> usbstorage -l
Failed to list the files: USB device not enabled.
switch:admin> usbstorage -e
Trying to enable USB device. Please wait...
sda: assuming drive cache: write through
Fail to enable USB storage device. Error:Device is not found or not formatted
My usb is Scandisk 8GB, my switch have FOS 7.4.2a
Broadcom Moderator
Hi,
it has to be Brocade USB (branded) with a specific directory if you are using admin with usbstorage CLI.  Better to troubleshoot your ethernent setup.
Contributor
[ Edited ]
Hello Martin;
thanks for your help.
regards.
