Anonymous
Firmware Problems
Hi,
We have a brocade switch in an IBM Blade Centre, an IBM engineer tried to upgrade the firmware and thing went wrond somewhere.
I am able to telnet onto the switch but the web interface no longer works.
If I do a "firmwarecommit" via telnet I get the following;
Validating the filesystem ...
missing /etc/fabos/pwron_fips_status
Firmwarecommit failed because Filesystem is inconsistent.
if I do a "version" i get;
brbroc3:USERID> version
Kernel: 2.6.14.2
Fabric OS: v6.0.1a
Made on: Thu May 22 17:55:06 2008
Flash: Wed Aug 13 15:59:17 2008
BootProm: 4.6.6
if I do a "firmwareshow" i get
Appl Primary/Secondary Versions
FOS v6.0.1a
Unknown
If i try a "firmwarerestore" I get
Cannot perform firmwarerestore because either firmwarecommit is running or
the secondary partition is corrupted.
Firmwarerestore failed - No firmwarerestore is needed. (0x1f)
A Switchshow gives the following
brbroc3:USERID> switchshow
switchName: brbroc3
switchType: 37.1
switchState: Online
switchMode: Native
switchRole: Principal
switchDomain: 1
switchId: fffc01
switchWwn: 10:00:00:05:1e:57:61:03
zoning: OFF
switchBeacon: OFF
Area Port Media Speed State Proto
0 0 id N4 Online E-Port segmented,(incompatible)
1 1 cu N4 Online F-Port 21:00:00:1b:32:14:91:6d
2 2 cu AN No_Sync
3 3 cu AN No_Sync
4 4 cu AN No_Sync
5 5 cu AN No_Sync
6 6 cu AN No_Sync
7 7 cu AN No_Sync
8 8 cu AN No_Sync
9 9 cu AN No_Sync
10 10 cu AN No_Sync
11 11 cu AN No_Sync
12 12 cu AN No_Sync
13 13 cu AN No_Sync
14 14 cu AN No_Sync
15 15 -- N4 No_Module
16 16 -- N4 No_Module
17 17 -- N4 No_Module
18 18 -- N4 No_Module
19 19 -- N4 No_Module
I have a support call open with IBM but they don't seem to be getting anywhere, do you guys have any ideas?
I have attached all of the logs
External Moderator
Re: Firmware Problems
Phil,
from wich (Old ) FabOS Release do you have start the firmware upgrade ?
i see here 6.0.1a, wich release was before loaded in the Blade ?
TechHelp24
TechHelp24
Anonymous
I would be happy with any firmware version now as long as the switch works again, we will want to go to 6.1 at some point
External Moderator
Phil,
I do not understand which it want to say here.
Is the Blade Switch work now ?
TechHelp24
TechHelp24
Anonymous
Hi,
The BladeSwitch is not working.
I am unable to upgrade or downgrade the firmware is I try to run firmwaredownlod I get the following message;
Checking system settings for firmwaredownload...
Sanity check failed because firmwareDownload is already in progress
If I try to run a firmwarecommit I get;
I need a way or restoring FabOS to any version (perferable 6.0 or 6.1)
External Moderator
Phil,
i ask yesterday,
--->>>....wich release was before loaded in the Blade ?
with other word, from wich Release do you have start the Upgrade to 6.0 ?
TechHelp24
Anonymous
Ok sorry he was tring to downgrade the firmware not upgrade.
He was tring to downgrade the firmware from 6.1 to 6.0.1a
External Moderator
Phil,
first, --->>> If I try to run a firmwarecommit I get;
You cannot commit a Firmware with a corrupted Partition.
Second, i am a little confused, you have first Downgrade from 6.1 to 6.0, and will today Upgrade again to 6.1 ?
Just for curiosity what is the reason this Downgrade ?
I think you get Support from Brocade, and i dont think you can recovery the switch.
You can test at you risk, to reload again the 6.1.x release was loaded before the Downgrade to 6.0, or higher example 6.1.0d or 6.1.1if you have access.
I assume follow, during the Downgrade from 6.1 to 6.0 the POST during reboot was hang, and the Upgrade Procedure was interrupted.
TechHelp24
New Contributor
Hi
  Has a solution to the "inconsistent primary filesystem" been found I am getting the same errors on some of my switches.
  It's saying the following files are missing.
  /etc/sshd_config
Anonymous
Has a solution to this problem been found yet? Im experiencing the same issues
