New Contributor
FirmWare Upgrade for 5300
Hi All,
Need steps to do F/W upgrade the Brocade 5300 switch.
wher can i download F/W ?
FOS version = v6.4.1.0
Regards,
Ismail Anwer
Anonymous
Re: FirmWare Upgrade for 5300
You can download from Brocade if you have an support contract, otherwise you'l have to consult the webpage from your supplier/vendor, aka HP, EMC,IBM etc.
How to upgrade is described in the FOS admin guide.
Basically you have three options
-CLI
-Webtools
-BNA (or DCFM)
Easiest for you perhaps if to use webtools to upgrade.
Once logged on go to the firmware tab, fill in the text fields and off you go.
Anonymous
There is no 6.4.1.0 Fabric OS, it's called 6.4.1.
Why not 6.4.2b? 6.4.1a is about a year old by now.
