Anonymous
Finisar SFP+ problem
Hello.
We are trying to use Finisar SFP+ FTLF8528P2BCV with Genuine Brocade 5470, OEM Blade Switch for IBM Blade Center.
We recieve an error:
"Error: Port 16 port faulted due to SFP validation failure. Please check if the SFP is valid for the configuration."
sfpshow 16
Identifier:  3    SFP
Connector:   7    LC
Transceiver: 540c404000000000 200,400,800_MB/s M5,M6 sw Short_dist
Encoding:    1    8B10B
Baud Rate:   85   (units 100 megabaud)
Length 9u:   0    (units km)
Length 9u:   0    (units 100 meters)
Length 50u:  5    (units 10 meters)
Length 62.5u:2    (units 10 meters)
Length Cu:   0    (units 1 meter)
Vendor Name: FINISAR CORP.
Vendor OUI:  00:90:65
Vendor PN:   FTLF8528P2BNV-E5
Vendor Rev:  B
Wavelength:  850  (units nm)
Options:     003a Loss_of_Sig,Tx_Fault,Tx_Disable
BR Max:      0
BR Min:      0
Serial No:   PMH4HFA
Date Code:   121729
DD Type:     0x68
Enh Options: 0xfa
Status/Ctrl: 0x82
Alarm flags = 0x5, 0x40
Warn Flags = 0x5, 0x40
version
Kernel:     2.6.14.2
Fabric OS:  v6.3.1b
Made on:    Mon Apr 19 21:46:59 2010
Flash:      Tue Mar 22 20:20:01 2011
BootProm:   1.0.9
switchshow
switchName:     B-FC-01
switchType:     73.6
switchState:    Online
switchMode:     Native
switchRole:     Principal
switchDomain:   1
switchId:       fffc01
switchWwn:      10:00:00:05:33:6c:e9:78
zoning:         ON (default_conf)
switchBeacon:   OFF
Does anyone have a clue what can be the problem? Maybe we need to update the firmware?
Thanks for help, regards.
External Moderator
Re: Finisar SFP+ problem
--->>>Does anyone have a clue what can be the problem? Maybe we need to update the firmware?
You must use Brocade Genuine SFP.
Thirds Part Vendor SFP are not supported, and FOS Upgrade no resolve the problem.
TechHelp24
