New Contributor
Accepted Solution
Fabric with FOS 8.1 and connected AG with FOS 6.4 ?
Hello,
I know that are compatibility matrix for each FOS release, but how do follow regarding switche's connected as Access Gateway to the fabric? So let's say I have a fabric with FOS 7.4 and connected few access gateways with FOS 6.4 - how would they react if I would upgrade the fabric to 8.1?
Thanks,
Stephano
External Moderator
Re: Fabric with FOS 8.1 and connected AG with FOS 6.4 ?
@Stephano
FOS 6.4 cannot coesist in a Fabric with FOS 8.x, not matter if the Switch fosconfig is Native or as AG.
FOS 8.x required a minimun of FOS 7.3
TechHelp24
New Contributor
Thank you. Regards!
Frequent Contributor
[ Edited ]
To add a bit more info on how you can find the answer to FOS compatibility the Brocade Release Notes are a good source.
You can find the release notes on MyBrocade.com and many are searchable using Google.
Example from FOS v8.1.0c Release Notes page 45:
Supported Products Fabric OS Interoperability
4100, 4900, 7500, 7500e, 5000, 200E, 48K Brocade 4012, 4016, 4018, 4020, 4024, 4424
No support for interoperability in the same fabric or Access Gateway connection — must use FCR
Brocade 5410, 5480, 5424, 5430, 5431, 5432, 5450, 5460, 5470, NC-5480, VA-40FC
v7.3.1 or later
Brocade DCX, DCX-4S, 300, 5100, 5300 v7.3.1 or later  Brocade DCX with FS8-18 blade(s), Brocade Encryption Switch  v7.3.1 or later
Brocade 7800, DCX and DCX-4S with FCOE10-24 or FX8-24 blades v7.3.1 or later
Brocade 8000 v7.1.2 or later1
Brocade DCX/DCX-4S with FA4-18 blade(s) No support for interoperability in the same fabric — must use FCR2
Brocade DCX 8510-8/DCX 8510-4 FOS v7.3.1 or later
Brocade DCX 8510-8/DCX 8510-4 with FC16-64 blade FOS v7.3.1 or later
Brocade DCX 8510-8 with FCOE10-24 blade FOS v7.3.1 or later
Brocade 6510, 6505, 6530, 7840 FOS v7.3.1 or later
6548, 6547, M6505, 6545, 6546 FOS v7.3.1 or later
The comments and advise included are the author's and do not mirror the views and opinions of any company. Any comments, advise, statements or references are without warranty, liability or claims of expertise. You should seek the assistance of the professional entity for subject matter being pursued.
