Anonymous
Fabric licensing question
We currently have two fabrics with three switches each, and we're currently expanding the network to include more switches.
We've been told by a HP engineer that we can only have 5 switches in each fabric, and will require license upgrades to allow more switches in the fabric.
All the switches are Brocade, and we have fabric licenses for them. I can't see any mention of limitations in this document either:
http://community.brocade.com/docs/DOC-1696
The engineer sounds wrong to me, but I can find any documentation with stated limitations; can anyone confirm that there isn't a limitation and pointers to any documentation about it? Are there any other limits I should be aware of?
Super Contributor
Re: Fabric licensing question
--->>>...and we have fabric licenses for them.
Switch Type  / Model ?
on the prompt execute the command "licenseshow" and post the result here
If you have a Standard "Fabric License" installed, no other License is required to build a Fabric.
If you are satisfied with the responses please mark as 'Answered'.
If not, just let me know I can see to get more info.
I would appreciated if you rate the threads.
Thank you.
Anonymous
We have a real mix of switches, I've just included the license names and not the codes. The licenses are the same for both fabrics.
Brocade 200E's:
    Web license
    Zoning license
    Fabric license
    Ports on Demand license - additional 4 port upgrade
Brocade 5100's:
    Fabric license
    First Ports on Demand license - additional 8 port upgrade license
    Second Ports on Demand license - additional 8 port upgrade license
    Enhanced Group Management license
    8 Gig FC license
Brocade 5480 (from a HP blade centre):
    Fabric license
    Full Ports on Demand license - additional 12 port upgrade license
    8 Gig FC license
Super Contributor
as mention in my preview post and n the DOC
as you can see,  all switch have current a Fabric License installed.
All Switch are covered to Build a Fabric, no other LIC is required.
Thank you.
External Moderator
Many greeting to HP Engineering.
This statement is INCORRECT
TechHelp24
