Turn on suggestions
Showing results for
09-07-2011 07:12 PM
Is it possible to buy fabric watch licenses for blade centre switches which are in access gateway mode?
09-07-2011 09:39 PM
is supported but accordly Brocade AG Guide Limited.
09-08-2011 04:59 PM
I do have fabric watch license, no lcue what is it being used for? What do you do in your case?
09-09-2011 04:37 AM
Hi Guys
Fabric Watch is an extremely handy license to have and should be on all your switches. It can detect and number of problems and send them out via SNMP traps/alerts to your monitoring applications.
Its saved me a number of times. Well worth the money.
Cheers
David
09-10-2011 08:47 AM
I agree, very usefull
but configuring is a nightmare and sometimes the results are funny.
Like TX and RX values above 100% after resetting counters.
But over all a good feature.
Andreas
