Anonymous
FabOS firmware upgrade procedure
Can anyone confirm whether when firmware upgrade using the fimwaredownload command causes the switch to reboot?
Also if the switch reboots as part of this procedure is this disruptive to the data traffic flowing through the switch?
External Moderator
Re: FabOS firmware upgrade procedure
Usually and in a most switch are Upgrade non-disruptive, in other one and some switches and release are upgrade disruptive.
See follow example from a diverse release notes.
example 1
To ensure non-disruptive Hot Code Load (HCL), neighbor switches should be operating with FOS v6.2.x
prior to loading FOS v6.2.1 on the following platforms:
4012, 4016, 4018, 4020, 4024, 4100, 200E
example 2
When upgrading to FOS v6.2.1 from FOS v6.1.0g or earlier, the CPs do not fully synchronize until both
the new active and new standby CPs are running v6.2.1. This is normal behavior and the firmware
upgrade is still not disruptive.
example 3
The Brocade 8000 does not support non-disruptive hot code loads (HCL).
TechHelp24
Anonymous
I have been asked to upgrade my customers SAN Fabrics.
These fabrics support many of his mission critical systems
each fabric consists of five SW4100 SAN Switches each running FabOS version 5.0.4.
the customer wants to upgrade to FabOS 6.2.1
I am aware from the release notes that there is  a number of iterations require to get to FabOS 6.2.1
should I upgrade the pricipal swicthes in each Fabric first and then the remaining switches?
will this approach prove to be non disruptive to the data thorugh each switch?
sorry for being overly cautious but there is a lot at stake with these changes.
External Moderator
--->>> I am aware from the release notes that there is  a number of iterations require to get to FabOS 6.2.1
Your have to upgrade in Min. of 4 step's from v5.0.4 to 6.2.1 because direct Upgrade is not supported!
--->>> each fabric consists of five SW4100...
--->>> ....will this approach prove to be non disruptive to the data thorugh each switch?
when all device server's, array's and all other peripherial's are connected redundant in the same fabric,  your can be sure taht the traffic
is flowing without any interruption at 99,99% when the fabric is Correct configured.
Begin with FOS 5.1.0 to FabOS 6.x.x
For each non-director-class platform in your fabric, complete all firmware download changes before issuing the firmwareDownload command on the next switch to ensure a nondisruptive download.
i would be completed Firmwaredownload by all Switch to the next higher Release, and then begin with upgrade of next release.
Example:
from current 5.0.4 -> 5.0.5 by all switches
next from 5.0.5 -> 6.0.x by all switches
next from 6.0.x -> 6.1.x by all switches
and finally from 6.1.x -> 6.2.x
BTW, before you begin with a upgrade, check all switch for DUMP file.
Good luck!
TechHelp24
Contributor
Hi
I have a question. I must upgrade this switch. Just look below details
4100(Brocade-ID)   ------ Type 32   ----  2005-B32(IBM-ID) current version  v5.0.1b   -----------> until 6.4.2a
So I have planned these steps to obtain a non-disruptive process:
v5.1.1b; v5.2.0 b; v5.3.1b  ; v6.0.0c ; v6.1.1b;  v6.2.2b; v6.3.2b; 6.4.2a;
Is my process right??
Thanks in advance
External Moderator
biberbos,
this is ok, however keep in mind before you start with Upgrade, since you are at FOS 5.0.x execute the command "savecore" and check if any dump is available.
If yes remove before start with new FOS upgrade.
BTW. 6.4.3b is the latest supported release.
TechHelp24
Contributor
Thanks for your answer . I appreciate it.
So must I do it (execute "savecore" command) before upgrade to v5.1.1b in the whole process? one time??
External Moderator
one time only.
the command is supported till FOS 5.2.x, by FOS 5.3.x and above use "supportsave" and "supportftp"
for details refer command reference manuals
TechHelp24
Contributor
Thanks very much for your help
So to finish the plan in this scenario, it is going to be:
1. Savecore  (select option 1 to clean or remove core files created by daemons.)
2. upgrade to v5.1.1b;
3. upgrade to v5.2.0 b
4. upgrade to v5.3.1b
5. upgrade to v6.0.0c
6. upgrade to v6.1.1b
7. upgrade to v6.2.2b
8. upgrade to v6.3.2b
9. upgrade to 6.4.2a  or  upgrade to 6.4.3b (maybe)
External Moderator
Step 2,3 and 4 are ok.
This is Brocade suggested upgrade path for Open System Environments
FOS 6.0.0c -> FOS 6.1.2c -> FOS 6.2.2f -> FOS 6.3.2d -> FOS 6.4.3b
TechHelp24
