Anonymous
FabOS and management-port 802.1q VLAN-tagging?
Are there any plans to start to support 802.1q in management port? HP seems to have plans to support VLAN-tagging 2009Q3 for the iLO-port, but if FabOS won't allow to enter the tag-id for the VLAN, You can't configure the embedded Brocade-switches to a different management-segment...
External Moderator
Re: FabOS and management-port 802.1q VLAN-tagging?
miika
do you want to config VLAN on the embedded ethernet port on the management port?
TechHelp24
Anonymous
Yup, the management port for the OA (Online Administrator) (in the blade-enclosure) starts to support VLAN-tags in network configuration in Q3/2009, but the network config in the embedded switch doesn't seem to support for the the tag-ID...
External Moderator
VLAN Feature direct on the Brocade management port are currently not supported and cannot be configured.
Probable this feature will be available later, but i think this not work.
TechHelp24
