Anonymous
FOS upgrade procedure from 6.1.0 to 6.3.0 and downgrade procedure
Hello All,
Can you please send me the Brocade 5100 SAN Switch FOS upgrade procedure from 6.1.0 to 6.3.0. Also the roll back plan in case of any issues.
Regards,
Bhanoji Rao
bhanojig@gmail.com
External Moderator
Re: FOS upgrade procedure from 6.1.0 to 6.3.0 and downgrade procedure
From current 6.1.x to 6.2.x then to 6.3.x
6.4.x is the latest available Release.
Downgrade vice-versa, from 6.3.x to 6.2.x hen to 6.1.x
Firmwaredownload details, Upgrade / Downgrade are descripted in Release Notes.
TechHelp24
Anonymous
Hello,
Iam lookin specificall any document tht you have for upgrade and downgrade procedure specifically for the SAN Switch 5100
External Moderator
--->>>.....specifically for the SAN Switch 5100
procedure is the same for all SAN Brocade Switches Model / Type
--->>> Iam lookin specificall any document tht you have for upgrade and downgrade procedure.....
the command is "firmwaredownload"
Details are descripetd Step-by-Step in the Fabric OS Command Reference Manuals.
TechHelp24
Anonymous
check help firmwaredownload cmd:
pls find attached the guide:
If you find this correct pls make it correct. The procedure is very simple and be ware if you ar eusing windows server for firmware upgarde then download the windows version, otherwise use unix version, the unix version is the best.The guide is for 4 Gbps but it is all same except where upgarding after 6.0 it is supported 1 step up and the downgrade the same 1 step down. But if it is 5.x.x then you can go 2 steps up and 2 steps down.
Anonymous
Hi Hemanth,
I was not able to open the best practises guide. can you Please email me this guide @ bhanojig@gmail.com
Anonymous
I have sent it, if you find it helpful pls make the thread correct
