Anonymous
FCPH busy return code 1 : Invalid ELS Command Code
On a ED48000 running a FOS 6.3.2b
I have found a lot of  FCPH  busy xx 1  xx is the ports 27, 31, 110, 111, 155, 158, 159, 238, 239
/  1 is the reason code that means  Invalid ELS Command Code – the command code is not recognized by the recipient.
/fabos/cliexec/portlogdump:
time         task       event   port cmd  args
10:05:43.535 PORT       Rx3     158   12  84140a00,18159e00,03ef07a8,00000000
10:05:43.535 FCPH       busy    158       1
10:05:43.693 PORT       Rx3     159   12  22140a00,18159f00,0cb3ffff,13000000
10:05:43.693 FCPH       busy    159       1
10:05:44.088 PORT       Rx3     158   48  07150a00,18159e00,00820715,00000000
10:05:44.088 FCPH       busy    158       1
10:05:43.535
Port 158 ( Task:   PORT - Event: frame received, class 3 ) Basic Accept (BA_ACC) from 159E00 to   140A00 (OX_ID: 03EF, RX_ID: 07A8) 00
10:05:43.535
FCPH   busy 158 1
Port 158 ( Task:   FCPH - Event: received frame is busied ) Received Frame is busied
What does it mean ?
Is this a FOS or a device problem ?
Anonymous
Re: FCPH busy return code 1 : Invalid ELS Command Code
This is a device problem. You'll need to open up a case with your OEM vendor to have this analysed. It can have multiple causes.
