Contributor
FCIP Tunnel up no connection: NPVID -> E -> EX ->VEX ---VEX <-EX <-E <- NPVID
I have a POC I am trying to setup and am not seeing the issue in what I have.  The connection is a bit "odd" I have a pair of Brocade 8Gb 24 port switches at each "site" (physically linked with 1Gb CAT 5 cables between two racks) with a blade chassis of servers which the customer purchased QLogic FC switches so I put them into NPV mode.  Zones within site work fine.  I have implemented best practices of seperate "A" and "B" fabrics (and for sake of example I call them by colors "red", "blue", "green", "yellow")
Now I have a storage controller attached directly to the 24port Brocade SAN switches (two controllers with two connections to each switch). I want to link primary site "PSCFC01"  storage ports to remote site "RSCFC01" storage so I can do SAN replication. (and then repeat to join the "PSCFC02" storage to "RSCFC02").
I have the tunnels up and linked and can ping from both directions..
I created LSAN zones which contain the cross connected site WWPNs from each storage controller.  I don't think I have ever done single FCR at each site with expectation to set tunnel to join "GE0" -> Red / blue SANs    and  "GE1" -> yellow and green SANs.  I think their is some step I am missing to set link between the EX to VEX association?
I am likely missing something simple.  It has been a while sense I did FCIP...
Any help and comments would be appreciated.
Draft Lab Guide
Fibre Channel Router
Port layout
Port
Switch
Domain ID
Mode
0
lcpscfc01-00
101
EX
1
lcpscfc02-00
102
EX
2
3
16
lcrscfc03-ge0*
121
VEX
17
lcrscfc03-ge1*
122
VEX
18
19
20
21
* Make sure the ports are in the copper (default) ports, if optical is desired mode must be changed.
Step 1: Activate License Keys for FCIP and Routing
Step 2: Login to fibre router and set up port
Select fc port and rename port description
Set mode on port to EX (SAN Routed Port) Set port to "EX-Port" with matching fabric ID to Native mode.
Now enable the "Gi" ports for VEX mode for ports 16, 17 which will bridge FCIP to remote switch.
Choose switch and "FCR"
Set the FCR ID by choosing "Set Fabric ID" (switch will have to be set to "disabled" to change this ID) then select "Enable FCR"  and set Backbone ID to 20
(For lcrscfc03 site, ID will be 20,21,22,23,24  while lcpscfc03 site IDs will be 10,11,12,13,14)
Choose "VE/Vex Ports" and choose the first Ethernet port and set to VEX and set Domain ID
Port Summary of descriptions (upstream connections) as well as Fabric Domain IDs
Step 2:   Setup Zones Aliase and routed Zone
Under Zone Admin
Create aliases for each WWPN. Example is for "lcrscv70001" system Canister 1, port 1
Now create zone for storage
** Repeat above step exactly but this time name zone "LSAN_******".  This creates a Zone that can be routed.
Now add both zones created to the zone database, save to switches
Then activate by clicking "Enable Config" and then select desired version and click ok
Step 3:   Setup FCR IP and routes on Gigibit interfaces
Example: lcrscfc01 with below WAN IP mapping
PSC Ports
RSC Ports
lcpscfc03w1
  1. 10.101.42.1
0/16 (ge0)
lcpscfc03w2
  1. 10.101.42.2
0/17 (ge1)
lcrscfc03w1
  1. 10.101.42.3
0/16 (ge0)
lcrscfc03w1
  1. 10.101.42.4
0/17 (ge1)
Display mapping of ports: portcfgpersistentenable
portcfgpersistentenable SlotO 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 +---+---+---+---+---+---+---+---+---+---+---+---+---+---+---+--- Enabled YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES Slot 0 16 17 18 19 20 21 22 23 +---+---+---+---+---+---+---+--- Enabled YES YES YES YES YES YES YES YES Slot O geO gel ge2 ge3 ge4 ges Enabled YES YES YES YES YES YES" height="192" width="594">
This sets IP to port "16" which is the first SFP based Ethernet Port.
lcrscfc03:admin> portshow fciptunnel all
No FCIP Tunnels found
lcrscfc03:admin> portshow 0/16
portIndex:  16
portName: lcpscfc03-16
portHealth: No Fabric Watch License
Authentication: None
EX_Port Mode:   Enabled
Fabric ID:      23
Front Phantom:  state = Not OK  Pref Dom ID: 160
Fabric params:  R_A_TOV: 0      E_D_TOV: 0      PID fmt: auto
Authentication Type: None
Hash Algorithm: N/A
DH Group: N/A
Edge fabric's primary wwn: N/A
Edge fabric's version stamp: N/A
portDisableReason: None
portCFlags: 0x0
portFlags: 0x4021        PRESENT VIRTUAL U_PORT EX_PORT DISABLED LED
LocalSwcFlags: 0x0
portType:  12.0
portState: 2    Offline
Protocol: FC
portPhys:  255 N/A     portScn:   2 Offline
port generation number:    0
state transition count:    2
portId:    cb1000
portIfId:    4302002a
portWwn:   20:10:00:27:f8:4a:7e:e4
portWwn of device(s) connected:
Distance:  normal
Port part of other ADs: No
lcpscfc03
lcrscfc03
# Disable port then bind IP and set Gateway interface
lcpscfc03:admin> portdisable ge0
lcpscfc03:admin> portcfg ipif ge0 create 10.101.42.1 255.255.255.0 1500
Operation Succeeded
lcpscfc03:admin> portcfg iproute ge0 create 10.101.42.0 255.255.255.0 10.101.42.230
Route is an interface subnet
# Create FCIP tunnel from psc to rsc @ 512MB and 1Gb max rate
lcpscfc03:admin> portcfg fciptunnel 16 create 10.101.42.3 10.101.42.1 --min-comm-rate 512000   --max-comm-rate 1000000 -c 3 -d  lcpscfc03-ge0_lcrscfc03-ge0
# Re-enable interfaces
lcpscfc03:admin> portenable ge0
lcpscfc03:admin> portcfgpersistentenable ge0
lcpscfc03:admin> portenable 16
lcpscfc03:admin> portcfgpersistentenable 16
# Test via ping to remote site
lcrscfc03:admin> portcmd --ping ge0 -s 10.101.42.1 -d 10.101.42.3
# Display FCIP tunnel
lcpscfc03:admin> portshow fciptunnel all
Tunnel Circuit  OpStatus Flags    Uptime TxMBps  RxMBps ConnCnt CommRt  Met
16 -         Up      a------     1m5s    0.00 0.00    3      - -
Flags: tunnel: c=compression m=moderate compression a=aggressive compression
                 A=Auto compression f=fastwrite t=Tapepipelining F=FICON
                 T=TPerf i=IPSec l=IPSec Legacy
lcrscfc03:admin> portdisable ge0
lcrscfc03:admin> portcfg ipif ge0 create 10.101.42.3 255.255.255.0 1500
Operation Succeeded
lcrscfc03:admin> portcfg iproute ge0 create 10.101.42.0 255.255.255.0 10.101.42.230
lcrscfc03:admin> portcfg fciptunnel 16 create 10.101.42.1 10.101.42.3 --min-comm-rate 512000   --max-comm-rate 1000000 -c 3 -d  lcpscfc03-ge0_lcrscfc03-ge0
lcrscfc03:admin> portenable ge0
lcrscfc03:admin> portcfgpersistentenable ge0
lcrscfc03:admin> portcmd --ping ge0 -s 10.101.42.3 -d 10.101.42.1
lcrscfc03:admin> portenable 16
16 -         InProg a------    1m59s 0.00    0.00    2 -      -
Research Frame support for site to support jumbo frames across WAN: http://wikibon.org/wiki/v/How_to_configure_FCIP_on_Brocade_7500%27s
LC-Router >>portcfg ipif ge0 create 10.255.2.3 255.255.255.0 2250
2250 is the MTU size (2148, is FC Frame size)
Repeat of above but this time to bind ge1 and ge1
lcpscfc03
lcrscfc03
lcpscfc03:admin> portdisable ge1
lcpscfc03:admin> portcfg ipif ge1 create 10.101.42.2 255.255.255.0 1500
Operation Succeeded
lcpscfc03:admin> portcfg iproute ge1 create 10.101.42.0 255.255.255.0 10.101.42.230
lcpscfc03:admin> portcfg fciptunnel 17 create 10.101.42.4 10.101.42.2 --min-comm-rate 512000   --max-comm-rate 1000000 -c 3 -d  lcpscfc03-ge1_lcrscfc03-ge1
lcrscfc03:admin> portcmd --ping ge1 -s 10.101.42.2 -d 10.101.42.4
16 -         Up      a------       3s 0.00    0.00    5 -      -
17 -         Up      a------    1m12s    0.00 0.00    1      - -
lcrscfc03:admin> portdisable ge1
lcrscfc03:admin> portcfg ipif ge1 create 10.101.42.4 255.255.255.0 1500
Operation Succeeded
lcrscfc03:admin> portcfg iproute ge1 create 10.101.42.0 255.255.255.0 10.101.42.230
lcrscfc03:admin> portcfg fciptunnel 17 create 10.101.42.2 10.101.42.4 --min-comm-rate 512000   --max-comm-rate 1000000 -c 3 -d  lcpscfc03-ge1_lcrscfc03-ge1
lcrscfc03:admin> portenable ge1
lcrscfc03:admin> portcfgpersistentenable ge1
lcrscfc03:admin> portcmd --ping ge1 -s 10.101.42.4 -d 10.101.42.2
16 -         Up      a------       9s 0.00    0.00    5 -      -
17 -         Up      a------    1m18s    0.00 0.00    1      - -
Step 4: Now we create a zone for v7000s across sites
The router setup is to route between the WWP connections of the connected sites per table below.
Zones Routed
lcpscfc01_lcrscfc01
lcpscfc02_lcrscfc02
  (50:05:07:68:02:35:b7:83) IBM Corp
  (50:05:07:68:02:45:b7:83) IBM Corp
  (50:05:07:68:02:15:b7:84) IBM Corp
  (50:05:07:68:02:25:b7:84) IBM Corp
  (50:05:07:68:02:35:b7:ab) IBM Corp
  (50:05:07:68:02:45:b7:ab) IBM Corp
  (50:05:07:68:02:15:b7:ac) IBM Corp
  (50:05:07:68:02:25:b7:ac) IBM Corp
  (50:05:07:68:02:15:b7:83) IBM Corp
  (50:05:07:68:02:25:b7:83) IBM Corp
  (50:05:07:68:02:35:b7:84) IBM Corp
  (50:05:07:68:02:45:b7:84) IBM Corp
  (50:05:07:68:02:15:b7:ab) IBM Corp
  (50:05:07:68:02:25:b7:ab) IBM Corp
  (50:05:07:68:02:35:b7:ac) IBM Corp
  (50:05:07:68:02:45:b7:ac) IBM Corp
The above table will be created on each switch as a LSAN (routed) zone.  Below are the commands for each of the four switch sides.
lcpscfc01
lcpscfc02
lcrscfc01
lcrscfc02
Step 5: Now with the use of the Brocade Network Assistant GUI, we can quickly add switches and setup routed zones between the fabrics
Install 70day evaluation version of Brocade Network Advisor
na1202_brocade_windows
Username
Password
Administrator
password
Launch GUI login
Click to add new device
Input each of the six FC switches
Note that the three switches of each site are diagramed as being in a single connection
Now we can create a routed zone between the two sites for the v7000 controllers
Create LSAN zone
2)Typeinzone 4: 141 Ibi ÇIIP_New Zone New Member... OK Cancel Help Potential Members All Levels El lcrsctcO3 S 4 lcrsctcOl El lcrsctcO2 4 Type VMsN Name Product Type Class lcrsctcO3 lcrsctcOl lcrsctco2 site vl000s ¿3 Activate... :h la" height="374" border="0" width="576">
CLI LSAN zoning
lcpscfc03_lcpscfc01
lcpscfc03_lcpscfc2
lcrscfc03_lcrscfc01
lcrscfc03_lcrscfc2
External Moderator
Re: FCIP Tunnel up no connection: NPVID -> E -> EX ->VEX ---VEX <-EX <-E <- NPVID
have you created ONE or TWO LSAN config ?
I'm not sure, but i think such config you want/have created can not work with more than one LSAN
TechHelp24
Contributor
Yes there is / will be two VSAN segments.
The LSAN zone for the storage will be the interfaces in an LSAN that have "pscfc01" and "rscfc01" controller ports.  And a seperate LSAN containing controller ports of interfaces in "pscfc02" and "rscfc02".
Example attached of Aliase / WWPN from switch where I manually added the cross WWPN IDs to the LSAN_ zone
pscfc01rscfc01
zone:  lcpscv70001
                lcpscv70001_1_3; lcpscv70001_1_4; lcpscv70001_2_1;
                lcpscv70001_2_2
zone:  LSAN_lcpscv70001_lcrscv70001
zone:  lcrscv70001
                lcrscv70001_1_3; lcrscv70001_1_4; lcrscv70001_2_1;
                lcrscv70001_2_2
zone:  LSAN_lcrscv70001
alias: lcpscv70001_1_3
alias: lcpscv70001_1_4
alias: lcpscv70001_2_1
alias: lcpscv70001_2_2
alias: lcrscv70001_1_3
alias: lcrscv70001_1_4
alias: lcrscv70001_2_1
alias: lcrscv70001_2_2
What I don't follow is if their is any other step, besides creating the LSAN,  to join the two zones over FCR.
External Moderator
I don't think you can create a Routing with/between two LSAN, or better to say any such config is unknown to me.
TechHelp24
Valued Contributor
Hi there,
I have taken a look at the diagram and it is conceptually wrong:
You cannot connect two VEX port together, a VEX port only can be connected to a VE port (as well as a EX port can only be connected to a E port). The only way to perform the config you want to implement is to configure a BB fabric made up of the two fcip tunnels.
Rgds
Contributor
Thanks,
I figured that out via some RTFM and poking around and got the environment working.
What I miss configured is that the brocade R06 is "routing"  what it is actually doing is "Bridging"
NPVID -> E -> EX ->VE ---VE <-EX <-E <- NPVID
That works.  Because what I needed to do is merge the FC03 switches (R06 router switch fabrics) together such that they were "one switch"  from which I could then "Bridge" the "red to blue" and "green to yellow".
Here is updated diagram
That works as expected.
