Turn on suggestions
Showing results for
01-29-2015 07:12 AM
Hi , I have some HP Blade Chassis with Brocade Switches Model 4024 and 5480. There is also a 6510 in the same Fabric currently at FOS version 7.0.2c .
Before I upgrade the 4024 and 5480 need to now wich FOS is supported in this environment.
The SAN Health report recommends 6.4.3e as Target Version.
Where i can find this Information.
.THX Lutz
Solved! Go to Solution.
01-29-2015 08:29 PM
Lutz,
4020 is supported only till FOS 6.2.2 release. 6.2.2g is the latest release, announced in the next feew week.
5480 and 65xx are supported by FOS 7.3.x
01-30-2015 12:08 AM
Hi Antonio ,
thank you for the fast response. But now i have an other question.
The SANHealth report listed all 4020 in "MAINTENANCE SUPPORT ENDED" on the ALERTS Tab.
Does this concern to the Switch Hardware or the FOS ?
And what does this mean for my customer ? Switch replacement to newer hardware?
Can you pls send me a link to the doc where i find this information.
THX Lutz
01-30-2015 02:59 AM
Lutz,
the 4020 Blade is End of Support, since long time.
-->>And what does this mean for my customer ? Switch replacement to newer hardware?
Yes, I would suggest to Upgrade to, but no all Blade Center Server Models support NEW Switch Blade Generation.
