New Contributor
Accepted Solution
FABOS stop error after the power cycle - Brocade 300
After the power cycle, Brocade 300 SAN switch error occur, I can't even run ipAddrShow and even help.
Broadcom Moderator
Re: FABOS stop error after the power cycle - Brocade 300
Hi Randy,
what exact is your error message and what is your FOS level on the 300?
Broadcom Moderator
Hello,
which output do you get when executing a command? You should also try to connect via console/serial to switch, check the output during reboot, copy it and paste it here.
Thanks in advance
AG
New Contributor
Here is the exact error after I login.
Error: insmod iu-module causing previous reboot !!
04/20/17  07:05:02, fabos_state.2
04/20/17  07:05:03, smd-module, loading
04/20/17  07:05:03, loaded
04/20/17  07:05:03, raslog-modle, loading
04/20/17  07:05:03, basic-module, loading
04/20/17  07:05:03, trace-module, loading
04/20/17  07:05:04, loaded
04/20/17  07:05:04, fablog-module, loading
04/20/17  07:05:04, xprt-module, loading
04/20/17  07:05:04, isc-module, loading
04/20/17  07:05:05, loaded
04/20/17  07:05:05, tp-module, loading
04/20/17  07:05:05, hasm-module, loading
04/20/17  07:05:05, rscmon-module, loading
04/20/17  07:05:06, tomahawk-module, loading
04/20/17  07:05:07, loaded
04/20/17  07:05:07, portlog-module, loading
04/20/17  07:05:07, ki-module, loading
04/20/17  07:05:07, fss-module, loading
04/20/17  07:05:08, loaded
04/20/17  07:05:08, fabsys-module, loading
04/20/17  07:05:08, iu-module, loading
FABOS stop !
Fabric OS (SW300)
SW300 console login: admin
Password:
sysmodAttach open failed: No such device or address
Raslog Module Initialisation failed rc=-1
fabsys device open: No such device or address
can't get Sw model=1, default to SilkwormsysmodAttach open failed: No such devi
ce or address
sysconModel: : Illegal seek
can't get Sw model=1, default to SilkwormWarning: Default password not changed
for 'root' and 'factory'. Please login as 'root' to change them.
ce or address
ce or address
can't get Sw model=1, default to SilkwormSW300:admin>
Broadcom Moderator
[ Edited ]
Hello,
From the logs you have provided it is looking like to be an issue with the primary partition.
The best is to contact your OEM for try to proceed to recovery by executing a boot to the second partition and then to do a firmwaredownload to recover/repair original partition.
You can try command: hareboot and see if better before.
Also make sure to save curent configuration: configupload
