New Contributor
Accepted Solution
Evaluation Licenses for Brocade 300e Switch
Hello  Everyone
Brocade 300e
I am need to you help me, I need  trial license enables demonstration and evaluation of a ISL between two Switches Brocade 300e.
The customer currently has a brocade 300e with full fabric license but the test Switch does not have the license Fabric for the ISL
how can i request trial license  from brocade support
Thank you for your advanced.
Gabriel
Broadcom Moderator
Re: Evaluation Licenses for Brocade 300e Switch
Hello,
What is the FOS version of the switch?
Broadcom Moderator
Hello,
Attached is the document concerning temporary software licenses for a period of 60 days after the installation.
Read carefully the first page and note those are for trial propose and a purchase of the concerned license is needed for use the specific feature enabled and be sure to have full support.
New Contributor
The Version is V7.4.1c
Thanks
