Anonymous
Ethernet port test
Hi all
Can some one help me with the command to test the "Ethernet ports on my SANswith"
Can i use "porttest" command
Valued Contributor
Re: Ethernet port test
Hi,
That command is to check the FC ports, not the ethernet ones.
Kind regards
Anonymous
Hello
I mean is there any option to test the ethernet port ( with extra arguments)
Valued Contributor
You mean the management eth ports or the fcip ones?
rgds
Anonymous
management port, are we having any option to test it
Valued Contributor
hi,
With admin credentials you can use ping and ifmodeshow or ipaddrshow to test and check the eth0 config.
If you have root access to the switch, you can use all the standard linux tools, such as ifconfigmii-tool or ethtool to review the eth0 port.
rgds
