Anonymous
Encoding errors inside frame
Can someone please explain possible causes of encoding errors inside the frames. Is this more than likely a bad sfp or faulty port on the switch. I'm seeing these errors on our 24000. The majority of our ports show "0" for this entry but one port is reporting over 300.
External Moderator
Re: Encoding errors inside frame
Shineflew,Is these errors on the One Port only or allPort in the same Switch Blade? Whit the command "portErrShow" can see the detail by this error.
TechHelp24
Anonymous
The error is on only one port of the blade.
External Moderator
Shineflew,if is the error available after replace the SFP and Cable, i assume that the Blade is damaged.
TechHelp24
