Anonymous
E Ports on Brocade 20-Port 4Gb SAN Module
Guys, I have a simple question,
Does the Brocade 20-Port 4Gb SAN Switch Module for IBM blade chassis support E ports to setup an ISL? or does it require a special licenses?
Cheers,
Kisanka
Occasional Contributor
Re: E Ports on Brocade 20-Port 4Gb SAN Module
For ISL you do not need license. Only for trunking you need "Trunking License".
External Moderator
--->>>For ISL you do not need license.
accordly this case, most OEM Blade Switch coming with a Fabric License, at this point you are correct.
keep in mind some Standalone Switch require a Fabric License if you want to ISL "E_Port"
TechHelp24
Anonymous
Thanks a lot guys for the help..
