Contributor
Downgrade issues due to hash, and disabled rootaccount
[ Edited ]
Need to downgrade a switch from FOSv8.0.2c to 7.x
Error:
 Downgrade is not allowed because System hash type is not set to MD5
Root account is als disabled
Managed to change hash to md5 for admin account
When trying to do this fror default user account we gert an error
swd77:user>  passwdcfg --hash md5
RBAC permission denied.
Also when trying to enable the root account i see an error
1-  change root -e yes  (sucessfully)
2-  rootaccess --set required-mode consoleonly i see the error below
rbash: rootaccess: restricted: cannot redirect output
Any good tips ?
swd77:admin> passwdcfg --showhash -all
Account name: root
Password Hash Algorithm: SHA512
Account name: admin
Password Hash Algorithm: MD5
Account name: user
External Moderator
Re: Downgrade issues due to hash, and disabled rootaccount
@Thomas Karlend
--->>>Need to downgrade a switch from FOSv8.0.2c to 7.x
Switch Type / Model ?
what version of FOS 7.x you try to Downgrade ?
what is the reason for Downgrade ?
TechHelp24
Broadcom Moderator
Hi Thomas,
you need to run as admin to enable root / change password type:
swd77:admin>  userconfig --change root -e yes
swd77:admin>  rootaccess --set all
swd77:admin>  passwdcfg --hash md5
Notice that when you downgrade the switch from Fabric OS 8.0.1 or later, the downgrade is blocked unless the following two conditions
are met:
– The password hash type for all the users is changed to MD5.
– The switch hash type is changed to MD5.
