Turn on suggestions
Showing results for
01-16-2012 08:03 AM
Greetings,
We have a several 3800 and 3900 switches in our fabric and recently purchased two 5300 switches. The current firmware on the 5300's, v6.3.1a is not compatible with the 3800's currently running v3.2.1.
Two questions:
1. If we downgrade the 5300 to v6.0, will they be compatible with the 3800's? Also, is there a FW version for the 3800's that is compatible with the 5300?
2. Should we and is it recommended/supported to downgrade the new switches?
Thanks for any help,
John
01-16-2012 08:40 AM
1) FOS 6.0.x is not support by 5300
2) Begin FOS Rel. 6.1.x is Supported 5300, however this have the same restriction with FOS 3.2.1 as FOS 6.2.x and above excepted XISL and Ecryption, also you can leave the 5300 by 6.3.x
3) For 3000, 3200 and 3800 the latest release Available is 3.2.1c.
If you are satisfied with the responses please mark and "Rate" as 'Answered'.
If not, just let me know I can see to get more info.
I would appreciated if you rate the threads.
Thank you.
01-16-2012 08:45 AM
Thanks for the reply.
So, is there a version of Firmware for each switch, 5300 and 3800 that will work together, or is there no way to connect them via ISL in the same fabric?
Thanks again,
John
01-16-2012 08:53 AM
3.2.1c for 3800
5.3.2c for 3900
and 6.1.x to 6.4.x for 5300 supported 3.2.1c and 5.3.2c
all this can be used to ISL 3800, 3900 with 5300.
BTW,all this Info are listed and specified in Release Notes
