Contributor
Accepted Solution
Does enabling DLS lossless feature causes traffic disruption?
IHAC who has Brocade DCX4S FOS 7.4.1d (It has FICON connected) with DLS enabled without lossless feature. He wants to know if he enables the lossless feature during production hours would that be disruptive?
Broadcom Moderator
Re: Does enabling DLS lossless feature causes traffic disruption?
Hello,
Configuration change for enable lossless is not disruptive.
Contributor
Thanks Thierry
Contributor
Hi Thierry,
Is there any document which states the same ?
Customer asking for it
Ganesh
Broadcom Moderator
I have checked the documentations available but I have not found this clear statement. But reverse is also right, command reference and admin guides do not specify it as disruptive.
