Anonymous
Documentation for Brocade 6510 16Gb Fibre Channel SAN Switch
Hi.
  I am looking for the product manuals for the Brocade 6510 16Gb Fibre Channel SAN Switch. At the Documentation webpage (http://my.brocade.com/wps/myportal/documentation), under the Product Manuals section, where it says "Download By: Select Product", the Brocade 6510 SAN Switch is not listed. There's a Brocade 6505 SAN Switch, but that is not the same product. Where do I find the relevent documentation?
  Thanks.
External Moderator
Re: Documentation for Brocade 6510 16Gb Fibre Channel SAN Switch
6510 Hardware Manuals is attached.
Both 6505 and 6510 based same plattforms and support same FOS , excepted Port and Power Supply.
6505 fit max. 24 Port and fit only ONE Power Supple
6510 can be full populated with POD License to 48 Port.
for some other details should you refer both Datasheet.
TechHelp24
