Occasional Contributor
Disable telnet globally using brocade SAN network advisor?
I know how to do it via CLI but i was wondering if theres a way to disable telnet sessions globally using the Brocade SAN Network advisor 14.2 GUI?
External Moderator
Re: Disable telnet globally using brocade SAN network advisor?
@StoreGuy
you can disable - what is the reason i want to set Telnet disable ? - Telnet with ipfilter policy from a CLI, but make sure you have a alternate method to access to the switch.
From a BNA GUI, AFAIK is not supported
TechHelp24
