Anonymous
Direct connectivity issue with Brocade 825 and VNX 5100
Hi all,
             I have a VNX 5100 directly connected to windows 2008 server using Brocade 825 HBA. The HBA is not logged into VNX. I have manualy registered them in VNX, and presnt LUN's to server. But the LUNs are not visible from the server.
HBA Firmware version -- 3.2.0.0
HBA Driver Version -- 3.2.0.0
HBA BIOS vrsion -- 3.0.1.0
What should I do to bring up the connectivity.
Rgds,
Sreekanth.
Anonymous
Re: Direct connectivity issue with Brocade 825 and VNX 5100
Problem resolved now..
> Installed HCM software
> Logged in as administrator/password
> Discovered HBAs
> Select HBA > right click > Basic port configuration
> Change topology... from p2p >> Loop (Direct connectivity use FCAL)
> Apply.., disable and enable port.
Done!!!..
Anonymous
I red somewhere, setting speed to 4Gb resolves the issue.
