Contributor
Accepted Solution
Difference in switch firmware
On the director switch SAN256B-6 : Is there Something specific to IBM in the Firmware, or is it exactly the same as Brocade firmware ?
External Moderator
Re: Difference in switch firmware
@msingh08
there is no difference, however you should use suggested Approved / Qualified Vendor/OEM FOS Release accordly they Matrices due a Support.
Additional, if you have a FICON Environments you have strong to follow FICON Qualification Letter.
TechHelp24
