Anonymous
DS5000B switch ports going offline/online
Hi ,
I have two DS5000B switches just introduced in to the network and upgrade it to 6.2.2b ,then put them under observation for 24hrs where port#11,17 are keep going offline and online with a count of nearly 1500 times and the count is keep going on and port#9 on other switch. ..cleared the port stats and checking the interrupts and loss_of signal number keep growing, At this point nothing connected to the switch.what could be the issue ? any other diags the I can run to find why the ports are keep going on and off ? appreciate your valuable feedback on this...Thanks
sw11x-ops-08:admin> portshow 11
portName:
portHealth: No Fabric Watch License
Authentication: None
portDisableReason: None
portCFlags: 0x1
portFlags: 0x4001        PRESENT U_PORT LED
portType:  10.0
POD Port: Port is licensed
portState: 2    Offline
portPhys:  2    No_Module
portScn:   0
port generation number:    0
portId:    060b00
portIfId:    4302000f
portWwn:   20:0b:00:05:1e:90:52:ab
portWwn of device(s) connected:
Distance:  normal
portSpeed: N4Gbps
LE domain: 0
FC Fastwrite: OFF
Interrupts:        84574      Link_failure: 0          Frjt:         0
Unknown:           0          Loss_of_sync: 0          Fbsy:         0
Lli:               84574      Loss_of_sig:  56383
Proc_rqrd:         5          Protocol_err: 0
Timed_out:         0          Invalid_word: 0
Rx_flushed:        0          Invalid_crc:  0
Tx_unavail:        0          Delim_err:    0
Free_buffer:       0          Address_err:  0
Overrun:           0          Lr_in:        0
Suspended:         0          Lr_out:       0
Parity_err:        0          Ols_in:       0
2_parity_err:      0          Ols_out:      0
CMI_bus_err:       0
Port part of other ADs: No
sw11x-ops-08:admin> portshow 17
portName:
portCFlags: 0x1
portFlags: 0x1   PRESENT U_PORT
portType:  10.0
portPhys:  4    No_Light
portScn:   0
portId:    061100
portIfId:    43020013
portWwn:   20:11:00:05:1e:90:52:ab
Distance:  normal
portSpeed: N4Gbps
LE domain: 0
FC Fastwrite: OFF
Interrupts:        4416       Link_failure: 0          Frjt:
Lli:               4416       Loss_of_sig:  2944
Proc_rqrd:         0          Protocol_err: 0
Overrun:           0          Lr_in:        0
CMI_bus_err:       0
Anonymous
Re: DS5000B switch ports going offline/online
Port 11 has no module installed or the SFP is not correctly inserted.
See you output: portPhys:  2    No_Module
On port 11 i assume that the cable is not correctly inserted. The switch is not receiving any light from the other side of the link.
Are you using the correct cable types?
I hope this helps,
Andreas
Anonymous
Thanks Andres
Anonymous
Is your issue now fixed?
Andreas
Anonymous
Hi Andres,
Yes , it did resolved after replacing the SFP's. They were having bad optics.
Thanks
Anonymous
Good to hear that this fix your issue.
I would appresiate if you can mark the thread as correct or answered.
This can help others to find a proper solution.
Thanks,
Andreas
Anonymous
yes I did, Thanks again andreas
