Anonymous
DCX Port Blade Is not supporting 48000 SFP
Hi ,
We have 1G HBA hosts running in our infrastructure and our new fabric is DCX , DCX is not supporting 1G HBA hosts so we tried to swap the 48K SFP but it is not taking , it's throwing error(FC Speed Mismatch / Incompatible SFP).
We trying to replace the HBA but host is not supporting 2G HBA so we need to do something at switch end.
Can you please suggest us the soluton.
Thanks,
Bhanu
Contributor
Re: DCX Port Blade Is not supporting 48000 SFP
Use 4 Gbps SFP which supports 1,2 & 4 Gbps.
Anonymous
Tried FINISAR branded 4G SFP but it didnt supported so no we are trying for Brocade vendor SFP.
Keep you update the test results...
Anonymous
Since the 8G platforms Brocade only supports Brocade branded transceivers with the exception of certain (E)LWL or coloured SFPs.
Check the compatibility matrix for more details.
