External Moderator
Re: DCX ISL to 48000 problems
will,
try with this configuration procedure
portcfgpersistentdisable -->> Port_Number
portcfgspeed --> must be fixed as 4G since the Brocade 48000 support Only 4G SpeedMode
portcfgeport  --> Set Port Mode 2 E-Port only
portcfglongdistance LE Set VC init 1
portcfgqos --> Set on Off
portcfgnpivport --> Set on Off.
Trunking ( usually ) is by default enable
Set configured Port "portcfgpersistentenable"
let me know.
TechHelp24
Valued Contributor
It looks that the ISL on the Brocade 48000 side has not been correclty established.
An option to solve it would be to apply the workaround provided by . I suppose that you'll have to undo it afterwards to see if the both ends of the ISL merge without issues.
