New Contributor
DCFM - ISL Between two switches
Hi,
I have an ISL link between two switches. This trunk has two ports. A couple of days ago the Master port change from one port to the other.
Now the DCFM shows the link between the two swithces in yellow (Alarm). How can I acknowledge the alarm or change the condition to normal?
regards,
Broadcom Moderator
Re: DCFM - ISL Between two switches
Open a CLI session to both switches which are trunked. Run the command 'islshow' and report what the state of the ISLs are between the two. Run 'trunkshow -perf' and evaluate the traffic flow between the trunk members. Then run  'trunkdebug <port 1, port 2>' where the port 1 and port 2 are the ports which are members of the trunk that are failing(if you FOS supports this command). Example;
dcx_8510:admin>trunkdebug 4, 5
port 4 trunking is not enabled
port 5 trunking is not enabled
Record the output of the command. It will advise you of the issue with the ports not forming a trunk. If the information is not useful, start with the layer one and check for crc, bad eof, lync fail, lost of sync, etc' or other link errors by using; 'porterrshow' command. Clear the stats with 'statsclear' and 'slotstatsclear', then check again in 24 hours.
doc
Any and all information provided by me is for entertainment value and should not be relied upon as a guaranteed solution or warranty of mechantability. All systems and all networks are different and unique. If you have a concern about data loss, or network disconnection, please open a TAC service request for service through Brocade, or through your OEM equipment provider. If this provided you with a solution to this issue, Please mark it with the button at the bottom "Accept as solution".
Broadcom Moderator
If you have enabled the change tracking / fabric tracking:
Accept the changes to a fabric by choosing one of the following options:
• Select a fabric on the Product List or Connectivity Map and select Monitor > Accept Changes.
• Right-click a fabric on the Product List or Connectivity Map and select Accept Changes.
