Occasional Contributor
D-Port Test not starting
I am trying to establish a new link between 6510 Switches. Both of them are using identical 16G SR SFPs (HP QK724A). One is running FOS 7.4.1b and the other FOS 7.4.2c and both show the port in question as an Online D-Port. However,
fcsw-dus-b3:admin> portdporttest --show 22
D-Port Information:
Port: 22
Remote WWNN: 10:00:c4:f5:7c:2f:f9:94
Remote port index: 8
Mode: Manual
No. of test frames: 1 Million
Test frame size: 1024 Bytes
FEC (enabled/option/active): Yes/No/No
CR (enabled/option/active): Yes/No/No
Start time: Wed Jul 25 11:28:24 2018
End time: -------------------
Status: NOT STARTED
Test Start time Result EST(HH:MM:SS) Comments
Electrical loopback -------- NOT STARTED -------- ----------
Optical loopback -------- NOT STARTED -------- ----------
Link traffic test -------- NOT STARTED -------- ----------
Roundtrip link latency: unknown
Egress power: Tx: -2.5 dBm, Rx: Not Avail.
Ingress power: Rx: -2.2 dBm, Tx: Not Avail.
It stays in this state, manual prodding with portdporttest --start doesn't help either. How do I run the D-Port test?
Frequent Contributor
Re: D-Port Test not starting
Did you try portdisable/portenable on one side or on both sides?
Yes, I had already tried that, it didn't help.
Super Contributor
Hello,
I'am only thinking if the action is supported by HP SFP's.
Please mark this response as "Accept as Solution" if it answers your question.
Marian Bezeg
They are just branded Brocade SFPs.
External Moderator
@mgoetze
i had a customer with a similarly issue, here try the customer to start d_port test in a ISL / Trunk, and the test return Failed.
Now Q.:
1) is in you case a ISL/Trunk ?
2) are the Port on both site correct configured ?
3) what type of cable is in use OM3 or OM4 ?
4) did you try to run the command as admin or as root ?
TechHelp24
1) No, it's a D-Port link. The planned used later is as an IFL.
2) What are you looking for? I will paste the config of both ports.
3) Should be OM3
4) admin
fcsw-dus-b3:admin> portcfgshow 22
Area Number: 22
Octet Speed Combo: 1(16G|8G|4G|2G)
Speed Level: AUTO(SW)
AL_PA Offset 13: OFF
Trunk Port ON
Long Distance OFF
VC Link Init OFF
Locked L_Port OFF
Locked G_Port ON
Disabled E_Port ON
Locked E_Port OFF
ISL R_RDY Mode OFF
RSCN Suppressed OFF
Persistent Disable OFF
LOS TOV mode 0(OFF)
NPIV capability ON
QOS Port OFF
Port Auto Disable: OFF
Rate Limit OFF
EX Port OFF
Mirror Port OFF
SIM Port OFF
Credit Recovery ON
F_Port Buffers OFF
E_Port Credits OFF
Fault Delay: 0(R_A_TOV)
NPIV PP Limit: 126
NPIV FLOGI Logout: OFF
CSCTL mode: OFF
TDZ mode: OFF
D-Port mode: ON
D-Port over DWDM: OFF
Compression: OFF
Encryption: OFF
FEC: ON
FEC via TTS: OFF
Non-DFE: OFF
fcsw-bb-b2:FID128:admin> portcfgshow 8
Area Number: 8
Trunk Port ON
Long Distance OFF
VC Link Init OFF
Locked L_Port OFF
Locked G_Port OFF
Disabled E_Port OFF
Locked E_Port OFF
ISL R_RDY Mode OFF
RSCN Suppressed OFF
LOS TOV mode 0(OFF)
NPIV capability ON
QOS Port AE
Rate Limit OFF
EX Port OFF
Mirror Port OFF
SIM Port OFF
Credit Recovery ON
F_Port Buffers OFF
E_Port Credits OFF
NPIV PP Limit: 255
CSCTL mode: OFF
TDZ mode: OFF
D-Port mode: ON
Compression: OFF
Encryption: OFF
FEC: ON
FEC via TTS: OFF
8G Non-DFE: OFF(Auto)
External Moderator
@mgoetze
can you please change the speed level a fixed on both side ?
you should do that with port disable, however I don't know if this is productive
1)portcfgpersistentdisable port_number
2)portcfgspeed port_number
3)portcfgpersistentenable port_number
TechHelp24
sdiff shows some differences, not sure, but maybe there's something important that should match?
fcsw-dus-b3:admin> portcfgshow 22     | fcsw-bb-b2:FID128:admin> portcfgshow 8
Area Number: 22                       | Area Number: 8
Octet Speed Combo: 1(16G|8G|4G|2G)      Octet Speed Combo: 1(16G|8G|4G|2G)
Speed Level: AUTO(SW)                   Speed Level: AUTO(SW)
AL_PA Offset 13: OFF                    AL_PA Offset 13: OFF
Trunk Port ON                           Trunk Port ON
Long Distance OFF                       Long Distance OFF
VC Link Init OFF                        VC Link Init OFF
Locked L_Port OFF                       Locked L_Port OFF
Locked G_Port ON                      | Locked G_Port OFF
Disabled E_Port ON                    | Disabled E_Port OFF
Locked E_Port OFF                       Locked E_Port OFF
ISL R_RDY Mode OFF                      ISL R_RDY Mode OFF
RSCN Suppressed OFF                     RSCN Suppressed OFF
Persistent Disable OFF                  Persistent Disable OFF
LOS TOV mode 0(OFF)                     LOS TOV mode 0(OFF)
NPIV capability ON                      NPIV capability ON
QOS Port OFF                          | QOS Port AE
Port Auto Disable: OFF                  Port Auto Disable: OFF
Rate Limit OFF                          Rate Limit OFF
EX Port OFF                             EX Port OFF
Mirror Port OFF                         Mirror Port OFF
SIM Port OFF                            SIM Port OFF
Credit Recovery ON                      Credit Recovery ON
F_Port Buffers OFF                      F_Port Buffers OFF
E_Port Credits OFF                      E_Port Credits OFF
Fault Delay: 0(R_A_TOV)                 Fault Delay: 0(R_A_TOV)
NPIV PP Limit: 126                    | NPIV PP Limit: 255
NPIV FLOGI Logout: OFF                  NPIV FLOGI Logout: OFF
CSCTL mode: OFF                         CSCTL mode: OFF
TDZ mode: OFF                           TDZ mode: OFF
D-Port mode: ON                         D-Port mode: ON
D-Port over DWDM: OFF                   D-Port over DWDM: OFF
Compression: OFF                        Compression: OFF
Encryption: OFF                         Encryption: OFF
FEC: ON                                 FEC: ON
FEC via TTS: OFF                        FEC via TTS: OFF
Non-DFE: OFF                          | 8G Non-DFE: OFF(Auto)
