Turn on suggestions
Showing results for
05-15-2018 05:07 AM
Customer has 11 x IBM BladeCenters in use in their 'Legacy' environment.
Each gets FC connectivity via a Brocade 4020 SAN Switch module clipped into the Chassis.
When is End of Support for this HW?
They use a mix of FOS 6.0.x / 6.1.x / 6.2.x
Is there any support left for these versions?
If so: when does it expire?
Thanks in advance,
Simon.
05-15-2018 06:02 AM
Hello,
4020 is out of support.
There is no official Brocade support for these devices anymore.
05-15-2018 06:37 AM
Thank you for that, but the link refers to the End of Life, NOT the End of Support I was requesting.
Simon.
05-15-2018 06:41 AM - edited 05-15-2018 06:42 AM
Hello,
so another one.
https://community.brocade.com/t5/Fibre-Channel-SAN-Forums/FC-Switch-4024-and-5480/td-p/70434
Antonio Bongiorno TechHelp24 Posts: 5,250 Registered: 02-23-2004 Solution! Re: FC Switch 4024 and 5480 Options 01-30-2015 11:59 AM Lutz, the 4020 Blade is End of Support, since long time. -->>And what does this mean for my customer ? Switch replacement to newer hardware? Yes, I would suggest to Upgrade to, but no all Blade Center Server Models support NEW Switch Blade Generation. TechHelp24
